Change hostname
Hello, I would like your help, it is not the first time I install Hestia but this time, the title is like this:
USER - racknerd-****** - Hestia Control Panel
And I would not like that usually came out that USER - control.mydomain.com - Hestia Control Panel
Hi @DROZO,
You need to change the server’s hostname.
As root use this command (replace control.mydomain.com by the real one):
v-change-sys-hostname control.mydomain.com
Note: be sure control.mydomain.com points to your server’s public ip.
Hello, I understand, I just tried that but I get error because that is already defined, it makes me strange that this defined but in the title is not like that.
Captura de pantalla 2024-08-24 102811
If you remove the Cloudflare’s proxy you see the same title?
I have already deactivated it and I will wait for the changes to propagate.
It still shows racknerd in title.
hostname -f
php -r 'echo gethostname();'
Hello, I get this
Also check the configured Title in White Label section.
Server Settings -> White Label -> General -> Title
hostname -f should show the right hostname too.
grep -r racknerd /etc/
Hello, perfect, thank you very much with the whitelabel option I solved it.
You are welcome but please, check the last command because it should show the right hostname instead of racknerd.
Hello, I get this
I would edit /etc/exim4/update-exim4.conf.conf /etc/hosts and /etc/mailname and would remove/replace racknerd by the right one.
