I installed HestaCP and everything went well. Now I need to change the master IP. I already registered the new IP and transferred all accounts to that new IP. I am not able to delete the main IP, as it informs me that I cannot remove the master IP. How I do?
Hi @lpcs007, did you try to check here https://docs.hestiacp.com/cli_commands/panel_configuration_commands.html ? There are some IP related commands you can use to change IP.
