Hi, thanks for your work. I am new to using hestia and ubuntu server. Prior to that, he worked with West and Cent Os.
Installed hestia a few days ago: ver 1.1.0 master branch.
bash hst-install.sh --nginx yes --phpfpm yes --apache no --multiphp yes --named no --vsftpd no --proftpd yes --iptables yes --fail2ban yes --quota no --exim yes --dovecot yes --spamassassin no --clamav yes --mysql yes --postgresql no --hostname domain --email email --password passwd
Almost everything works fine. Faced that some values in php.ini are not applied. So it should be or is it a bug? I could solve the problem by creating my own templates in /usr/local/hestia/data/templates/web/php-fpm/
Đi, from hestia
in php.ini these values are present for all php cli versions and not for all fmp. And not applied to sites.
And yes, i restarted the phpX.Y-fpm
example: service php7.4-fpm restart.
the point is that settings are added from the panel, but are not applied on sites. so I had to make changes to the templates. I wrote about this in the very first message
Nothing to excuse your self, maybe you got me wrong: This thread got a bit chaotic, so I would like that we can discuss this in another thread - weâre here to help and improve hestia .
youâre very welcome @Raphael - thatâs why you have me
back to topic, I just tried on 1.1, deb 10, nginx+apache+multiphpâŚ
changes via GUI in the âsimpleâ interface are reflected as well as changes to the php.ini via the âadvancedâ
it seems to not really restart the service, but in the end does not need to, because fpm spawn fresh child processes anyway which read the php.ini again anyway if I am not mistaken.
Can i say i second this what Sergei was trying to say. I had a customer wanting to upgrade âMax Input Varsâ where as this is not part of the gui, it is part of the manual advanced section in the Gui. I modified the value from 1000 to 5000 which is what the client needed, but according to the dash board of wordpress and betheme the global change hadnt applied. I had to create a template and assign to it the client with the values Sergei, kindly put above. Im happy to elabrate if need be. But i had to create a bespoke template for the changes to work. And yes i did do restarts etc.
