First, Thanks to the community and creators for all you do!! been a silent user for over a year now. First post, here goes.
On a clean install I can not add or change IP’s with in the CP, I get a internal error.
This includes the default IP trying to remove NAT from that ip.
Trying to add a new IP i get a internal error. Here is the errors in the log.
2023/12/19 17:54:13 [error] 733#0: *5 FastCGI sent in stderr: "PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/templates/pages/edit_ip.php on line 58" while reading response header from upstream, client: 192.168.3.111, server: _, request: "GET /edit/ip/?ip=192.168.2.100&token=a7b133e711cd8e21eb7588c8219513dc HTTP/2.0", upstream: "fastcgi://unix:/run/hestia-php.sock:", host: "192.168.2.100:8083", referrer: "192.168.2.100:8083/list/ip/"
2023/12/19 17:54:17 [error] 733#0: *5 FastCGI sent in stderr: "PHP message: PHP Warning: Undefined array key "v_owner" in /usr/local/hestia/web/edit/ip/index.php on line 71; PHP message: PHP Warning: Undefined array key "v_owner" in /usr/local/hestia/web/edit/ip/index.php on line 72; PHP message: PHP Fatal error: Uncaught TypeError: Hestiacp\quoteshellarg\quoteshellarg(): Argument #1 ($arg) must be of type string, null given, called in /usr/local/hestia/web/edit/ip/index.php on line 72 and defined in /usr/local/hestia/web/inc/vendor/hestiacp/phpquoteshellarg/src/Hestiacp/quoteshellarg/quoteshellarg.php:14
Stack trace:
#0 /usr/local/hestia/web/edit/ip/index.php(72): Hestiacp\quoteshellarg\quoteshellarg()
#1 {main}
thrown in /usr/local/hestia/web/inc/vendor/hestiacp/phpquoteshellarg/src/Hestiacp/quoteshellarg/quoteshellarg.php on line 14" while reading response header from upstream, client: 192.168.3.111, server: _, request: "POST /edit/ip/?ip=192.168.2.100&token=a7b133e711cd8e21eb7588c8219513dc HTTP/2.0", upstream: "fastcgi://unix:/run/hestia-php.sock:", host: "192.168.2.100:8083", referrer: "192.168.2.100:8083/edit/ip/?ip=192.168.2.100&token=a7b133e711cd8e21eb7588c8219513dc"
2023/12/19 17:54:23 [error] 733#0: *5 FastCGI sent in stderr: "PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/templates/pages/edit_ip.php on line 58" while reading response header from upstream, client: 192.168.3.111, server: _, request: "GET /edit/ip/?ip=192.168.2.100&token=a7b133e711cd8e21eb7588c8219513dc HTTP/2.0", upstream: "fastcgi://unix:/run/hestia-php.sock:", host: "192.168.2.100:8083", referrer: "192.168.2.100:8083/list/ip/"
2023/12/19 17:58:58 [error] 733#0: *19 FastCGI sent in stderr: "PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/templates/pages/add_ip.php on line 65" while reading response header from upstream, client: 192.168.3.111, server: _, request: "GET /add/ip/ HTTP/2.0", upstream: "fastcgi://unix:/run/hestia-php.sock:", host: "192.168.2.100:8083", referrer: "192.168.2.100:8083/list/ip/"
2023/12/19 17:59:23 [error] 733#0: *19 FastCGI sent in stderr: "PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/templates/pages/add_ip.php on line 65" while reading response header from upstream, client: 192.168.3.111, server: _, request: "GET /add/ip/ HTTP/2.0", upstream: "fastcgi://unix:/run/hestia-php.sock:", host: "192.168.2.100:8083", referrer: "192.168.2.100:8083/list/ip/"
2023/12/19 17:59:26 [error] 733#0: *19 FastCGI sent in stderr: "PHP message: PHP Warning: Undefined array key "v_owner" in /usr/local/hestia/web/add/ip/index.php on line 51; PHP message: PHP Fatal error: Uncaught TypeError: Hestiacp\quoteshellarg\quoteshellarg(): Argument #1 ($arg) must be of type string, null given, called in /usr/local/hestia/web/add/ip/index.php on line 51 and defined in /usr/local/hestia/web/inc/vendor/hestiacp/phpquoteshellarg/src/Hestiacp/quoteshellarg/quoteshellarg.php:14
Stack trace:
#0 /usr/local/hestia/web/add/ip/index.php(51): Hestiacp\quoteshellarg\quoteshellarg()
#1 {main}
thrown in /usr/local/hestia/web/inc/vendor/hestiacp/phpquoteshellarg/src/Hestiacp/quoteshellarg/quoteshellarg.php on line 14" while reading response header from upstream, client: 192.168.3.111, server: _, request: "POST /add/ip/ HTTP/2.0", upstream: "fastcgi://unix:/run/hestia-php.sock:", host: "192.168.2.100:8083", referrer: "192.168.2.100:8083/add/ip/"
2023/12/19 17:59:29 [error] 733#0: *19 FastCGI sent in stderr: "PHP message: PHP Warning: foreach() argument must be of type array|object, null given in /usr/local/hestia/web/templates/pages/add_ip.php on line 65" while reading response header from upstream, client: 192.168.3.111, server: _, request: "GET /add/ip/ HTTP/2.0", upstream: "fastcgi://unix:/run/hestia-php.sock:", host: "192.168.2.100:8083", referrer: "192.168.2.100:8083/list/ip/"
