Cloudflare and ERR_TOO_MANY_REDIRECTS, is there a solution?
I would like to know if there is any solution to this problem, it would be a problem to stop using one of the two, or Hestia or Cloudflare.
That error is usually caused by using the insecure Flexible setting on Cloudflare. Change your Cloudflare SSL mode to Full (Strict).
If you are using Let’s Encrypt certificates issued by your Hestia server, you will need to insure that your Cloudflare settings are compatible. The alternative is to use a Cloudflare Origin CA certificate.
thanks, this solved the issue for me
Full (strict)
Encrypts end-to-end, but requires a trusted CA or Cloudflare Origin CA certificate on the server
