Cloudflare R2 for Backups
i guess so… tried running the rclone script again and get this:
The latest version of rclone rclone v1.59.2 is already installed.
im assuming i need to downgrade rclone?!
No you need to download a beta / “main” branch build
okay got it now thanks
also anything worth placing in the .config/rclone/rclone.conf besides upload_cutoff = 5Gi ?
I didn’t make any changes except entered my aws key details
i did the beta rclone update earlier today, went into hestiacp and disabled, saved then enabled r2 backup.
First batch of backups im still getting ‘Can’t login to sftp host …’
Make sure that you have the current main branch working it should be merged right now
okay installed main will try a backup soon
backups went fine, all good. whats the stance with the larger than 5gb tarballs? is there any chance that when the backup script is done it weighs in what protocol is used (in this case rclone) and chops up the archives into 5gb pieces to accommodate the backup limits?
i noticed that files larger then 5gb are being uploaded to r2, not sure who to thank but its all good now. had one that was 9.2gb too
There seems to be a bug with older versions of Rclone it has been patched …
what about auto deleting anything older than the last 15 backups on r2? is that something we can do or would i need to chase it up with cf because i am manually deleting them atm?
Doesn’t it delete when it passes the number backups in a package?
i just checked and theres no max limit for the r2 side of it, i did a reinstall of main the other day too
Screenshot 2022-11-07 at 07.58.13
This is the limit that should be taken in account
And this takes care of it…
Or this code:
thanks for that but i am running main from a few days ago and do not see the option to choose it, that is sftp has the option to specify the limit in the admin panel but not rclone / r2 that is, setting the backup count.
It can be changed at the package level…
oh yeah i forgot that lol mine was set to 300 when i was doing local cloud. set it correctly now. thanks, as this is a godsend being on cgnat now. kudos to you guys that dev’ed this and your help in this thread is appreciated!!
