Cloudflare SSL with Hestia CP
Hey guys :slight_smile:
Newbie here… I have read “Please read this before you start”. However, I am stuck :smiley:
So, I installed Hestia on Ubuntu 22.04, and everything went well until I tried to set up Cloudflare’s SSL to Hestia CP (settings- SSL, copy-pasted the certificates), and saved. And from that moment onwards, I can’t access Hestia CP…
For the past 10 days, I’ve tried everything ChatGpt told me… :smiley:
Has anyone managed to get this working, and HOW? If you’ve seen any tutorial of it, it would be great if you can share it :slight_smile:
Thanks! :smiley:
Of course, I’ve tried all of this. It doesn’t work. I wouldn’t be on this forum if it did. :slight_smile: If anyone has made Cloudflare SSL work on Hestia, pls send me a message… Thanks :slight_smile:
If you disable the Cloudflare proxy, can you access to Hestia CP? What exact error does it show? Keep in mind that using the Cloudflare proxy doesn’t support port 8083 (Cloudflare doesn’t allow it), so you can change the port in Hestia to one that Cloudflare does support, such as 2083.
If you provide more details about what you’ve done and how you’ve done it, as well as the actual domain, we can likely make progress toward resolving it.
Cloudflare support port 8083 with https and cache, for reference, you can check on Cloudflare page.
Edit: yeah, I was wrong, too busy and still typing. Is not supported.
  • 80
  • 8080
  • 8880
  • 2052
  • 2082
  • 2086
  • 2095
HTTPS ports supported by Cloudflare
  • 443
  • 2053
  • 2083
  • 2087
  • 2096
  • 8443
Ports supported by Cloudflare, but with caching disabled
  • 2052
  • 2053
  • 2082
  • 2083
  • 2086
  • 2087
  • 2095
  • 2096
  • 8880
  • 8443
Is not supported…
Unless you disable proxy with Cloudflare
Change it to 2083 and it should work fine
