Thank you very much @Raphael for your prompt response. For what I have been reading, I agree with you.
Any pointers on the install script?
bash hst-install.sh –nginx yes --apache no –phpfpm yes–multiphp yes –vsftpd yes --proftpd no --exim yes --dovecot no --clamav no --spamassassin no –mysql yes --lang es --hostname sub.domain.com
Is there something missing or something that I don’t need?
Nginx cache support is only works for sites with heavy load. For 1 visitor in 10 min the advantages doesn’t out way disadvantages. (More disk wear it doesn’t take the advantages of caching). Also a lot of plugins will break and can cause multiple issues with less preformance and non functional cache so be careful with it …
Multiphp I should use no and only install the version you really need. Probally 7.3 / 7.4 and 8.0. PHP 5.6 / 7.0 / 7.1 / 7.2 should probally just die…
For the size / type of server it depends on the load / performance you need. I have websites where I can host 1000 sites on server or sites where max 5 on 1 server it depends on the traffic
An “exploit” that allows certain function limitations bypasses.
I use no cache plugin but I have mainly “static” pages and so It works great with Nginx Cache. Woocommerce with “baskets” or themes that count page views will break with nginx cache. For example…
I agree that Nginx+FPM might be better resource-wise and speed-wise, but you need to also check beforehand if there are any sites / plugins / whatever, that depends on .htaccess files. Unless you have the time / will to convert those configs.
Usually Nginx + FPM will be enough. But what I usually do nowadays is: I set Nginx > Apache > PHP-FPM. And in case Apache not required, web-server configuration can be adjusted to exclude Apache. As you mentioned WordPress, I think that Apache will be required for some components, as from my experience… But obviously it depends on your requirements, and no1 knows it better then you)
In an ideal world: Nginx + FPM BUT if I host woocommerce then not.
Since I will host woocommerce and some plugins might need .htaccess then I need apache.
@Felix said that Nginx+FPM might need a lot of adaptations or tweakings. And I am not willing to spend my time. I’d rather get more cores and ram.
So @Vadym said, Nginx + Apache + FPM. Maybe it is the solution but how?
Set static webs with Nginx + FPM
Rest of webs with Nginx + Apache
And then if I add cache on top of it the solution remains the same?
Set static webs with Nginx + FPM + Cache
Rest of webs with Nginx + Apache + Cache
And what about PHP legacy websites? Host a new VPS with all the bullshit websites and increase the hosting price because of the legacy headaches until they buy a new website?
What will happen when PHP 7.3 gets old. Will I then need multiphp?
For WordPress I would use Apache as @eris is suggesting above. Also from my lately experience with WordPress (.htaccess related).
Also I would pick latest PHP for most of the websites where I will isolate legacy PHP websites on different VPS/server.
Lately I’ll try moving the websites that us old PHP to newer PHP versions to avoid security risks.
HTH
Thank you all for the discussion. I hope someone else will find it interesting too.
I will stick to apache + nginx for broader compatibility with the WordPress ecosystem and less headaches.
I think that I could easily make a guide with recommendations for common use cases so that newbies / non-sysadmins have a reference to get hestia running.
