Please check your email! I sent you the documentation! I can’t participate in your development library!
Hello @yunli! Yes, I confirm about the force parameter. in the script, it is handled the same way in the case of --force no and --force yes. I fixed this behavior in the installation script. I also made the default behavior for determining IP of the server, now IP is determined out of NAT. To enable the internal IP during installation, you must explicitly set the --nopublicip yes parameter. I also installed PHP from the remi repository by default and added the installation of clamav databases without a mirror by default. I hope the site with documentation works well, I didn’t see any troubles with it. I have commit changes to the repository.
Which library do you mean? github/hestiacp-rpm? I will check the permissions
