Connection error on web terminal
I can ssh to server as normal user fine, if i access hestiacp via
IPAddress:8083 login as user web terminal works fine
BUT
USERDOMAIN.com:8083 = Connection error
SUBDOMAINofserver.com:8084 = Conneciton error
I tried adding
proxy_set_header Host $host;
to /usr/local/hestia/nginx/conf/nginx.conf and restarting nginx but no change.
Hestia Control Panel v1.9.4
  • Operating SystemUbuntu 24.04 (x86_64)
Hestia only validates the connection if it comes from the server’s ip or the server’s hostname, any other domain/sub-domain is rejected.
Hostname under configure server > basic options and hostname in /etc/hosts match hestiacp hostname but still Connection error. Are there any files which store this value in case there are stale entries causing it?
are you using cloudflare?
no not using cf
But, are you connecting to Hestia using that hostname https://hostname:8083 ?
yes i’m using https://hostname:8083 and i get conneciton error
Could you please share the hostname?
Fixed it. When accessing https://sub.mydomain.com:8083 it tried to read the cookie header that doesn’t exist and ends up crashing the terminal service thus connection error.
