https://hcp.domain.com:8083 times out and so does phpMyAdmin but all the websites and mailboxes (including domain.com) work. It’s wotth noting that I don’t get the 404 page, I get a generic browser message “The connection has timed out. Check internet connection…”
It was all working a few days ago, I can’t think what might have changed.
I can SSH into the server using the admin account.
I’ve ran /usr/local/hestia/bin/v-add-letsencrypt-host
If your server is hcp.yournick, then port 8083 is not open, I would double check your TP-Link router’s conf because seems you are not forwarding port 8083 correctly.
Yes, now I see it open and can see the login page.
Do you have an open port 2531 that you should close because seems anyone could reboot your router, I didn’t try to reboot it so maybe it doesn’t work but you should check it.
