Contributing to development
Good morning all, I would love to start helping and contributing in terms of the development of hestia.
I have a linux vm running on my desktop and would like to know how I can start getting my hands dirty with development of hestia.
How does one go about getting started?
For basic to complicated stuff
Translations:
Only knowledge for your non locale language … Takes about 3 / 4 hours for the first time depending on status of and then few “seconds” to maybe few minutes every week/month to keep them up to date
Documentation
Fork Hestia CP and clone it
Run: npm ci
Then make the changes via your editor and run the website locally with npm run docs:dev
And make a PR when done
Bug fixes / Feature development
Fork the project
Check for outstanding issues:
See: Contributing to Hestia’s development | Hestia Control Panel
Make the changes you want and send a PR :slight_smile:
We will try to review it and merge it when it works
A quick question to go about installing the fork I am assuming its the same process as one would do as per the standard installation process?
Yes if follow the steps from Building packages | Hestia Control Panel
It is only really needed if you make changes to the installer.
Otherwise:
v-update-sys-hestia-git fork:branch will work fine
