Correct Fresh Installation of HestiaCP SMTP
Hello, I would like to perform a clean installation of HestiaCP from scratch. I want to use only SMTP for sending emails (with OVH mail server). Of course, each domain will have its own login accounts and mail servers. Is Exim enough on its own?
Yes it is
Damn, I’m having trouble with the configuration…
I go to the “Mail” tab,
add the domain - domain.com,
check SMTP, fill in the host and port,
move on, add accounts, enter the login and password.
Is this how an SMTP configuration should look?
Am I missing something, or do I not understand something…?
Well. Your DNS should be configured correctly so other servers take your SMTP seriously.
It works out of the box…
Check if ovh has port 25 blocked.
telnet ssl0.ovh.net 25
Trying 193.70.18.144…
Connected to ssl0.ovh.net.
220 GARM-96R001 Sunday, November 24, 2024
i think is work?
2024-11-24 02:53:45 1tEsYj-0000t2-2p Message is frozen
2024-11-24 02:55:54 1tExf4-000D06-Or H=otherdomain.com [45.33.18.44]: SMTP timeout after initial connection: Connection timed out
2024-11-24 02:58:05 1tExf4-000D06-Or H=otherdomain.com [72.14.185.43]: SMTP timeout after initial connection: Connection timed out
hmm?
i dont know where search a problem…
i have good dns from ovh
but prestashop mail smtp system same no work wtf?
i dontt have any logs
