CP Domain not accesible
Hi all,
I installed Hestia in my Ubuntu 22 VPS to learn and test etc
During install I chose the CP fqdn of CP.mydomain.co.uk
In my cloudflare account for the domain I added a record of CP.mydomain → my IP address.
I turned off proxy in cloudflare (I believe I should?)
I installed domain certificate which was successful and now shows in the control panel with it expiry date and other details etc
I performed a tracert to the domain which successfully finds my VPS and shows all correct visibly as I turned off proxy above
When I goto Https://CP.mydomain.co.uk:8083 it takes ages then fails with cannot find server.
If I replace domain with IP all works as it should.
What am I missing?
Thanks for any advice
Cloudflare doesnt support port 8083, you need to switch to anotherone - have a look at the search function, has been handled already a few times :).
