Create IP list based on ASN gives Error: iplist file too small
I would like to create an IP list based on a ASN as suggested on the IPverse Github page.
For example: 141.98.11.16 (based in Lithuania) generates ASN: 209605.
I create the IPset url like so:
https://raw.githubusercontent.com/ipverse/asn-ip/master/as/209605/ipv4-aggregated.txt
When trying to add the link I get the following error:
Error: iplist file too small (<10), ignoring
I’m aware of this ‘problem’ but not aware of a workaround since I can’t edit this file manually.
Any thoughts?
Thanks!
You can combine multiple ipset files like this:
If you create an second ipset file with for example
1.1.1.1/32
1.1.1.2/32
Thank you @eris!
