I am getting the following via email from Cron Daemon.
Subject Line: test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
Email Body: run-parts: /etc/cron.daily/ntpdate exited with return code 1
Subject Line: test -x /usr/share/roundcube/bin/cleandb.sh && /usr/share/roundcube/bin/cleandb.sh >/dev/null
Email Body: PHP Warning: count(): Parameter must be an array or an object that implements Countable in /usr/share/roundcube/program/lib/Roundcube/rcube_plugin_api.php on line 438
Repeated about 20 times in email.
Running Debian 9.11 New Default Install
Everything seems to be working great.
Any idea on why these are being reported?
-Mark
Also kudos on the name, Hestia. Had to look it up and then it made sense!
Not sure I want to install the latest Roundcube as it’s a Beta. Stable version - 1.3.10 doesn’t necessarily seem to have the fix, so if there is no risk, might just let it do it nightly output error.
What about the ntpdate error what is that related to? I looked at the configs and ran a manual
