Cron does not run within CP
So I’m currently running a larval site and im running two cron commands.
I run them in the public_html folder
sudo php artisan app:sitemap-generate
sudo php artisan schedule:run
If i run both the commands within the CLI it works fine
Also if i run them like this in the CLI also works fine
now if i run the same commands in the hestiacp cron page it will not run
Don’t use sudo …
if i change it to
/home/username/web/website.com/public_html/artisan app:sitemap-generate
still the same not seeming to work
I use always:
cd /home/username/web/website.com/public_html/ && /home/username/web/website.com/public_html/artisan app:sitemap-generate
And never have an issue
its still the same not execution the command i will have to look into it more
to see if it my setup that’s stopping it
service cron status
If it is not running, then it needs to be started.
su user
and then run
cd /home/username/web/website.com/public_html/ && /usr/bin/php8.3 /home/username/web/website.com/public_html/artisan app:sitemap-generate
And it should work fine
And that should be the cronjob as well…
no mater what way I enter it into the hestiacp i will not run
I have ended up using it with
crontab -e
          • sudo /home/username/web/website.com/public_html/artisan app:sitemap-generate
and that works i will leave it like this for now
thanks for all your help
Then you ru n the code as root. You don’t want to do that…
