neven
November 27, 2021, 9:03am
#1
Hi
After upgrade, cron jobs started to fail.
Example of an error:
sh: 19: cd: can’t cd to /tmp/tmp.9KfcXxjpja Execution directory inaccessible.
I don’t a alow execution from tmpfs, as I consider it unsafe. (noexec for /tmp in fstab)
Is this the problem? (Everything was OK up to 1.5.0)
BR,
Neven
eris
November 27, 2021, 9:30am
#2
What cronjob creates this error?
neven
November 27, 2021, 9:48am
#3
I have no Idea.
How can I find that?
I know only what the number of the cronjobs that failed (114, 115, 116, 117 and 118) from the error log, and that they are jobs from admin user:
spooled jobs fro this user are:
*/2 * * * * sudo /usr/local/hestia/bin/v-update-sys-queue restart
15 02 * * * sudo /usr/local/hestia/bin/v-update-sys-queue disk
10 00 * * * sudo /usr/local/hestia/bin/v-update-sys-queue traffic
30 03 * * * sudo /usr/local/hestia/bin/v-update-sys-queue webstats
*/5 * * * * sudo /usr/local/hestia/bin/v-update-sys-queue backup
10 03 * * * sudo /usr/local/hestia/bin/v-backup-users
20 00 * * * sudo /usr/local/hestia/bin/v-update-user-stats
*/5 * * * * sudo /usr/local/hestia/bin/v-update-sys-rrd
43 5 * * * sudo /usr/local/hestia/bin/v-update-letsencrypt-ssl
*/5 * * * * sudo /usr/local/hestia/bin/v-update-sys-queue letsencrypt
12 5 * * * sudo /usr/local/hestia/bin/v-update-sys-hestia-all
01 00 * * * sudo /usr/local/hestia/bin/v-update-sys-queue daily
*/5 * * * * sudo /usr/local/hestia/bin/v-update-sys-queue dns-cluster
N.
neven
November 27, 2021, 9:58am
#4
Could be this:
(from hesitia error log)
2021-11-27 03:30:01 v-update-web-domain-stat ‘admin’ ‘domain1.com ’ [Error 3]
2021-11-27 03:30:05 v-update-web-domain-stat ‘admin’ ‘domain2.com ’ [Error 3]
2021-11-27 03:30:12 v-update-web-domain-stat ‘admin’ ‘domain3.com ’ [Error 3]
2021-11-27 03:30:12 v-update-web-domain-stat ‘admin’ ‘domain4.com ’ [Error 3]
2021-11-27 03:30:12 v-update-web-domain-stat ‘admin’ ‘domain5.com ’ [Error 3]
N.
cmstew
November 28, 2021, 5:42am
#5
Just confirming that I had this very same issue. I haven’t been able to track down what caused it yet though.
neven
November 28, 2021, 9:25am
#6
Had some time today, so I executed all spooled jobs manually.
0 errors.
Can you perhaps update the script that creates this entry:
with the name of the script that is being executed?
N.
cmstew
December 4, 2021, 7:27pm
#7
That’s what the problem was, we didn’t know what script was generating it. It took me awhile to trace the issue back to it’s source, but we haven’t figured out a fix for it just yet.
It’s related to letsencrypt ssl renewal and it’s harmless. Just annoying. We’ll fix it soon.
