My cron jobs are not running according to the configured timing. For example, I set one cron job to run every minute:
* * * * * curl --request GET 'https://xxx.com.my/index.php?option=com_ajax&plugin=cronjobdelyva&method=onAjaxcronjobdelyva&format=json' > /dev/null 2>&1
But the execution is delayed:
Cron ran at: 2026-07-26 19:35:01
Cron ran at: 2026-07-26 19:38:01
The same issue happens for all cron jobs, not only this one.
Is there any HestiaCP setting or log I can check to find out why cron execution is delayed?
Hestia version: 1.9.6
