I am facing problems with cron jobs. Please help me fix.
Error 1:- When I enter this below in cron jobs
sudo /usr/bin/php -q /home/test/web/test.com/public_html/account/crons/cron.php
I am getting this error
sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper
sudo: a password is required
Error 2:- Now when I try with curl
/usr/bin/curl /usr/bin/php -q /home/test/web/test.com/public_html/account/crons/cron.php
I am getting the error now
curl: (3) URL using bad/illegal format or missing URL
Note I have entered right url where test.com is my domain name.
Please help me fix it and how to enter right cronjob also ioncube loader is also installed. Your help will be appreciated. Thank you.
PHP Fatal error: The file /home/test/web/itest.com/public_html/account/crons/cron.php encoded as type [1/81] cannot be decoded by this version of the ionCube Loader.
in Unknown on line 0
I have tried with pho 7.4 and 8 also but getting same error and website is up and running only have with cronjob.
I am using real domain name I just changed it to test here on the forum.
