Default crontab on the admin user doesn’t work and I don’t receive any notification emails.
I check exim4 log and I can’t see any mail started to notify the cron job ends.
I check crontab log, I see the cron job that start the command and nothing else.
Please, help me… can I check additional logs to understand the problem?
if I lunch manually the command, for example, v-backup-users, it works fine.
In my opinion, it would be very nice to have a basic notification by email, which you can activate or deactivate… in my case the v-backup-user job does not start, or rather, I can see it in the crontab log but the backup is not executed. How do I know what the error is?
inside syslog file I see cronjob log but it contains only the command executed and I don’t understand if the command ends correctly or not…
Command executed, any notification email, any backup created…
