Css not found after update
I updated hestiacp through the cli. After completion I got the following error:
nginx: [emerg] "real_ip_header" directive is duplicate in /etc/nginx/conf.d/cloudflare.inc:29 nginx: configuration file /etc/nginx/nginx.conf test failed
And also the css of the admin panel cant be found 404.
cat /etc/nginx/nginx.conf
How did you update the packages?
I used the following command to update: v-update-sys-hestia-git
cat /etc/nginx/nginx.conf:
`# Server globals
user www-data;
worker_processes auto;
worker_rlimit_nofile 65535;
error_log /var/log/nginx/error.log;
pid /run/nginx.pid;
include /etc/nginx/modules-enabled/*.conf;
Worker config
events {
worker_connections 1024;
use epoll;
multi_accept on;
http {
# Main settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
client_header_timeout 180s;
client_body_timeout 180s;
client_header_buffer_size 2k;
client_body_buffer_size 256k;
client_max_body_size 256m;
large_client_header_buffers 4 8k;
send_timeout 900s;
keepalive_timeout 30s;
keepalive_requests 100000;
reset_timedout_connection on;
server_tokens off;
server_name_in_redirect off;
server_names_hash_max_size 512;
server_names_hash_bucket_size 512;
charset utf-8;
# FastCGI settings
fastcgi_buffers                 8 256k;
fastcgi_buffer_size             256k;
fastcgi_busy_buffers_size       256k;
fastcgi_temp_file_write_size    256k;
fastcgi_connect_timeout         30s;
fastcgi_read_timeout            300s;
fastcgi_send_timeout            180s;
fastcgi_cache_lock              on;
fastcgi_cache_lock_timeout      5s;
fastcgi_cache_background_update on;
fastcgi_cache_revalidate        on;
# Proxy settings
proxy_redirect                  off;
proxy_set_header                Host $host;
proxy_set_header                X-Real-IP $remote_addr;
proxy_set_header                X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_pass_header               Set-Cookie;
proxy_buffers                   32 4k;
proxy_connect_timeout           1600s;
proxy_read_timeout              1600s;
proxy_send_timeout              1600s;
# Log format
log_format  main    '$remote_addr - $remote_user [$time_local] $request '
                    '"$status" $body_bytes_sent "$http_referer" '
                    '"$http_user_agent" "$http_x_forwarded_for"';
log_format  bytes   '$body_bytes_sent';
log_not_found off;
access_log off;
# Mime settings
include             /etc/nginx/mime.types;
default_type        application/octet-stream;
# Compression
gzip                on;
gzip_static         on;
gzip_vary           on;
gzip_comp_level     6;
gzip_min_length     1024;
gzip_buffers        16 8k;
gzip_http_version   1.1;
gzip_types          text/plain text/css text/javascript text/js text/xml application/json application/javascript application/x-javascript application/xml application/xml+rss application/x-font-ttf image/svg+xml font/opentype;
gzip_proxied        any;
gzip_disable        "MSIE [1-6]\.";
# Cloudflare https://www.cloudflare.com/ips
include /etc/nginx/conf.d/cloudflare.inc;
# SSL PCI compliance
ssl_session_cache   shared:SSL:20m;
ssl_session_timeout 60m;
ssl_buffer_size     1400;
ssl_protocols       TLSv1.2 TLSv1.3;
ssl_prefer_server_ciphers on;
ssl_ciphers         "ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS";
ssl_dhparam         /etc/ssl/dhparam.pem;
ssl_ecdh_curve      secp384r1;
ssl_session_tickets off;
resolver 127.0.0.53  valid=300s ipv6=off;
resolver_timeout    5s;
# Error pages
error_page 403 /error/404.html;
error_page 404 /error/404.html;
error_page 410 /error/410.html;
error_page 500 501 502 503 504 505 /error/50x.html;
# Proxy cache
proxy_cache_path /var/cache/nginx levels=2 keys_zone=cache:10m inactive=60m max_size=1024m;
proxy_cache_key "$host$request_uri $cookie_user";
proxy_temp_path  /var/cache/nginx/temp;
proxy_ignore_headers Expires Cache-Control;
proxy_cache_use_stale error timeout invalid_header http_502;
proxy_cache_valid any 1d;
# FastCGI cache
fastcgi_cache_path /var/cache/nginx/micro levels=1:2 keys_zone=microcache:10m max_size=1024m inactive=30m;
fastcgi_cache_key "$scheme$request_method$host$request_uri";
fastcgi_cache_methods GET HEAD;
fastcgi_cache_use_stale updating error timeout invalid_header http_500 http_503;
fastcgi_ignore_headers Cache-Control Expires Set-Cookie;
add_header X-FastCGI-Cache $upstream_cache_status;
# Cache bypass
map $http_cookie $no_cache {
    default 0;
    ~SESS 1;
    ~wordpress_logged_in 1;
# File cache (static assets)
open_file_cache          max=10000 inactive=30s;
open_file_cache_valid    60s;
open_file_cache_min_uses 2;
open_file_cache_errors   off;
# Wildcard include
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/conf.d/domains/*.conf;
I also received the next error per mail:
And the following:
PHP Warning: Failed loading Zend extension 'ioncube_loader_lin_5.6.so' (tried: /usr/lib/php/20210902/ioncube_loader_lin_5.6.so (/usr/lib/php/20210902/ioncube_loader_lin_5.6.so: cannot open shared object file: No such file or directory), /usr/lib/php/20210902/ioncube_loader_lin_5.6.so.so (/usr/lib/php/20210902/ioncube_loader_lin_5.6.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0 PHP Warning: Failed loading Zend extension 'ioncube_loader_lin_5.6.so' (tried: /usr/lib/php/20210902/ioncube_loader_lin_5.6.so (/usr/lib/php/20210902/ioncube_loader_lin_5.6.so: cannot open shared object file: No such file or directory), /usr/lib/php/20210902/ioncube_loader_lin_5.6.so.so (/usr/lib/php/20210902/ioncube_loader_lin_5.6.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0 Error: nginx restart failed Error: nginx restart failed PHP Warning: Failed loading Zend extension 'ioncube_loader_lin_5.6.so' (tried: /usr/lib/php/20210902/ioncube_loader_lin_5.6.so (/usr/lib/php/20210902/ioncube_loader_lin_5.6.so: cannot open shared object file: No such file or directory), /usr/lib/php/20210902/ioncube_loader_lin_5.6.so.so (/usr/lib/php/20210902/ioncube_loader_lin_5.6.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0 Error: nginx restart failed
Make sure to install npm / nodejs and then run the command again in it was an old version it didn’t do it
But If I was you just run v-update-sys-hestia-all so it will also update the rest …
Remove one of the following lines:
Thanks @eris I removed one line of two include /etc/nginx/conf.d/cloudflare.inc;
Just ran v-update-sys-hestia-all, but it did nothing. After ~2-3 seconds it returned to just another line on the terminal.
edit: v-update-sys-hestia-all doesnt work at all. I used v-update-sys-hestia-git again, and this time it worken without errors, after I disabled ionCube loader from the php settings. But I still have the css/js not found errors.
Do you have nodejs installed?
Could you share the output?
Yes, after I installed nodejs the css/js of the admin panel is working again, thank you very much @eris. Heel erg bedankt:)
v-update-sys-hestia-all still doesn’t work, does basically nothing I think; no output whatsoever…
v-update-sys-hestia-git does update some packages. The nginx restart failure is due to ioncube not found. I’m guessing because I have the ioncube loader only in the /etc/something/php5.6 folder, and not in the other versions.
edit: After trying again nginx has no problems restarting. It only reports this error, but does restart fine.
note:
It also seams the system automatically appends ‘.so’ while trying to locate the file? becuase in the warning line the second not found object ends in ‘.so.so’
On what version are you on
apt list hestia*
For
See Install Ioncube on Hestia | Hestia Control Panel
hestia-nginx/focal,now 1.25.2 amd64 [installed]
hestia-php/focal,now 8.2.11 amd64 [installed]
hestia/focal,now 1.8.10 amd64 [installed]
I think I wnt through that post, I have ioncube installed and working for a long time -for just 1 accunt btw, so I’m thinking of just removing it-
It looks like it is last version so no wonder why it didn’t install the packages…
I dont know update-all does absolutely nothing. I disabled auto-updates because I had some problems one time after an auto update. It has been a long time since I manually updated. Could that have anything to do with it?
Anyway thank you very much @eris again. Css/js is loading correctly and my admin panel is useable once again.
