Curl: (23) Failure writing output to destination
I need to install composer on the server. To install it, follow the documentation on how to install composer on Debian 12, which says the following instructions:
curl -sS https://getcomposer.org/installer -o composer-setup.php
When running, it gives the following error: curl: (23) Failure writing output to destination
Investigating the error, I found the following:
After a very long research I found a useful hint.
Can’t write to a hidden path using Curl
Basically snap curl is useless. Uninstall it properly. Get the proper apt curl, and everything works like a charm.
The question is: Can I uninstall Curl in Hestia and reinstall it, as indicated there?
v-add-user-composer user
Will install composer in /home/user/.composer/composer
Thanks, I logged in as root and installed as recommended: v-add-user-composer user.
Then I went to /home/ususrio/web/usuario.cl/public_html and typed composer.
-bash: composer: command not found
use the full path /home/user/.composer/composer --version
Gracias:
An error occurred with the dependencies and the php version, when using composer update. How can I install the latest version of php?
