Hello. How can I make my own pages like 404, 403 and others?
It will be enough to place them in the folder /var/www/document_errors
It is necessary that after updating the panel nothing is rewritten. Thank you
There is an option in the settings where you can disable overwrite the default custom docs then you can safely edit them in /usr/local/hestia/data/templates/web/skel/document_errors
I donβt have this folder
root@hcp:/usr/local/hestia/data/templates# ls
dns mail web
Sorry it is /usr/local/hestia/data/templates/web/skel/document_errors
Please specify which parameter exactly.
Check the system policies it should be there some where β¦
Server Settings β Configure β Security β Policies β Sync Error document templates on user rebuild β No β Save
