Custom Backup Script: Weekly Backups with Monthly Retention
I’m sharing a custom backup script I use for my HestiaCP server. It creates weekly backups (4 per month) and automatically keeps only the most recent backup from previous months, helping save disk space while maintaining a good backup history.
Features:
Creates organized backups in date-structured directories (e.g., /backup/12 DEC 2025/)
Maintains symlinks in /backup/ for HestiaCP panel compatibility
Symlinks are essential - they allow HestiaCP to update backup counters correctly and enable users to download, restore, and delete backups from the panel, even though backups are organized in monthly folders
Automatically cleans orphaned backups
Optional: Keep only 1 backup per user from previous months (configurable)
HTML email notifications with full backup summary
Detailed logging for each backup session
Database integrity checks before backup
Robust cleanup of temporary files and incomplete backups
Change it to: 00 01 * * 0 sudo /usr/local/hestia/bin/v-backup-users-custom
Adjust the time as needed (current example: Sunday at 1:00 AM)
Configuration Options:
At the top of the script, you can customize:
# Auto-detect admin user with ROLE='admin' (leave empty)
ADMIN_USER_OVERRIDE=""
# Use CONTACT email from admin user (leave empty)
# Or set manually: ADMIN_EMAIL_OVERRIDE="[email protected]"
ADMIN_EMAIL_OVERRIDE=""
# Keep only 1 backup per user from previous months (TRUE/FALSE)
# When TRUE: Keeps only the most recent backup from previous months
# When FALSE: Keeps all backups (default HestiaCP behavior)
KEEP_ONLY_ONE_OLD_BACKUP="FALSE"
How it works:
Runs weekly (or as configured in cron)
Creates backups in organized folders: /backup/DD MMM YYYY/username/
Maintains symlinks in /backup/ for panel compatibility
These symlinks are crucial - they allow HestiaCP to:
Update backup counters (U_BACKUPS) correctly
Display backups in the user panel
Enable download, restore, and delete functions
All functions work normally despite backups being organized in monthly folders
If KEEP_ONLY_ONE_OLD_BACKUP="TRUE", automatically removes old backups from previous months, keeping only the latest one per user
Sends HTML email summary with backup status
Logs everything for troubleshooting
User Panel Compatibility:
Even though backups are stored in organized monthly folders, all HestiaCP panel functions work perfectly:
Users can see their backups in the panel
Download backups directly
Restore backups with one click
Delete backups from the panel
Backup counters are updated correctly
This is possible because the script maintains symlinks in the /backup/ directory that point to the actual backup files in the organized folders.
Remote Backup Support:
You can customize this script to work with remote backups (FTP, SFTP, B2, Rclone) by modifying the backup functions. The script is based on HestiaCP’s original v-backup-user logic but with enhanced organization and cleanup features.
I have already custom for daily,weakly,monthly creating username_daily etc and replacing the old one! Good job and thanks for sharing! I can provide also the scripts if someone need.
I don’t use GitHub, and it’s not something so special that it needs to be shared.
in the file:
/usr/local/hestia/data/users/USER_XX/backup.conf
You have the complete list of all backups for each account.
and in:
/usr/local/hestia/data/users/USER_XX/user.conf
You have the stored backup counter U_BACKUPS=‘’
You just need to go through each user’s list, determine which backups you want to delete (by age), and update the backup counter (user.conf) and their backup list (backup.conf).
You can create your own backup schedule—daily, weekly, monthly, annual, whatever you want.
You don’t need to use anyone else’s.
An easy, simple, and extremely useful solution if you don’t have a minimum of knowledge of BASH is to use this data to ask your preferred AI; I assure you it will give you an easy and simple script to understand.
The amount of code you will need is well below 5kb, including extensive comments.
IMPORTANT:
The difference with this idea is that it’s not actually a backup program, it’s a backup deletion program.
pd
Furthermore, my backup cleaning script is tailored to my needs and I handle external backups, so I add an extra layer that is unnecessary for most people.
It looks large because I included a more elaborate email template.
Also, instead of using v-backup-users, I copied its contents directly into my script. I could call it externally, and the script would be much smaller.
Quick update for anyone finding this thread — the repository URL has moved to webxtekstudio and this module was completely redesigned into backup-core-patches based on the exact feedback discussed above:
No more monolithic v-backup-users-custom clone: Instead of duplicating HestiaCP’s backup script, it now uses lightweight native hooks (v-backup-user-hook, v-backup-users-notify-hook, v-backup-user-notify-hook) directly on top of HestiaCP’s native v-backup-user / v-backup-users.
Automatic survival across HestiaCP updates: Includes an APT DPkg::Post-Invoke hook (/etc/apt/apt.conf.d/99-hestia-custom-backup-hooks) that automatically re-links the hooks whenever the hestia package updates.
Standalone GFS Retention CLI (v-prune-backups): Configurable via /etc/hestiacp-backup-retention.conf (KEEP_DAILY_FOR_DAYS, KEEP_WEEKLY_FOR_WEEKS, KEEP_MONTHLY_COUNT) with --dry-run and --apply modes. It prunes both organized local folders (/backup/YYYY/MM_MONTH/user/) and Backblaze B2 buckets while keeping HestiaCP’s backup.conf, U_BACKUPS counter, and /backup/*.tar symlinks in sync.
B2 Cloud Retry & Backup Integrity Verifier (v-verify-backups): Adds a 3-attempt retry wrapper around b2 file upload to prevent transient network failures from aborting backups, plus v-verify-backups to audit local/B2 archive existence, size, and age per user.
Dark-mode HTML email reports with backup.log attached (zero inline log bloat).
Quick Install:
git clone https://github.com/webxtekstudio/hestiacp-useful-tools.git /root/hestiacp-useful-tools
cd /root/hestiacp-useful-tools
bash scripts/backup-core-patches/install.sh
Full toolkit (11 HestiaCP modules including 6-pillar server hardening, CrowdSec nftables, Exim anti-spoofing/size limits, and security audit):
Note on your existing v1 backups: You do not need to move or rename your existing /backup/DD MMM YYYY/username/ folders. All existing symlinks in /backup/ continue to work in the HestiaCP panel, and v-prune-backups automatically scans all subdirectories under /backup/ (both old v1 folders and new v2/backup/YYYY/MM_MONTH/username/ folders), cleaning up expired archives, symlinks, empty folders, and backup.conf counters automatically.
