Custom cron not firing
Hey guys, perhaps someone can help me. I’ve put together a custom script to backup some docker files to s3, and added it to the cron list with Hestia. However, it doesn’t fire, no notifications are sent, no output in the logs. Just pasting the same command in the terminal works without any issues. Am I doing something wrong here? Thank you!
you need to adjust the sudoer’s file, that you have enough permission on that path OR just add it in root crontab (without sudo then).
