Hello, it seems that the white label option is not working, I have added the files to the /usr/local/hestia/web/images/custom/ path as indicated in the instructions, but selecting update logo and saving does not change any logo, I have tried this even with a new test server and the same thing happens, does anyone else have the same thing?
See: Feature/2493 change logo support by jaapmarcus · Pull Request #3572 · hestiacp/hestiacp · GitHub
Make sure to clear the caches of your browser …
Thanks, it worked by running the command v-update-white-label-logo, although I noticed that you also have to upload logo-header.svg instead of logo-header.png, otherwise it doesn’t get changed.
