Am I missing a key step?
I’m trying to set up a pleroma (fediverse) server just for a few users. Pleroma is lightweight, a fairly easy install, and seems like a good choice. I’ve closely followed the OTP release instructions here (Installing on Linux using OTP releases - Pleroma Documentation).
Where I deviated was to instead have hestiacp create the user, and I’ve adjusted the instructions for the different home dir of the new Hestia pleroma user. I used Hestiacp to create a mail domain, but did not use it to create a web domain, instead leaving that for the nginx config provided by the instructions.
As per the instructions, I installed and use CERTBOT to get the letsencrypt certs (turning nginx off temporarily). I have pleroma running and can access it directly. The only issue I’m having is getting nginx to load the pleroma config. I put the provided file (altered with the correct domain) into /etc/nginx/conf.d/domains/pleroma.conf.
nginx -t shows OK.
restarting nginx happens without error.
visiting http:// or https://example.tld shows the default Hestia created page saying “Success! Your new web server is ready to use.” This is the same page you get if you don’t have a web domain created in the control panel, yet have a domain name pointing at the server. If I delete pleroma.conf and restart the server, I’m getting the same page.
I don’t see anything wrong with the nginx.conf the pleroma team have provided. I don’t receive an error to nginx -t. It just appears to be skipped over, like it simply didn’t load.
Do file permissions for pleroma.conf have to be something particular?
Is there a verbose mode when starting nginx that might report additional errors?
Am I missing something?
Any suggestions on how to proceed would be very welcome.
For reference, this is the contents of pleroma.conf (apologies for how it’s formatting, I thought blockquote would present it as text):
# default nginx site config for Pleroma # # Simple installation instructions: # 1. Install your TLS certificate, possibly using Let's Encrypt. # 2. Replace 'example.tld' with your instance's domain wherever it appears. # 3. Copy this file to /etc/nginx/sites-available/ and then add a symlink to it # in /etc/nginx/sites-enabled/ and run 'nginx -s reload' or restart nginx.proxy_cache_path /tmp/pleroma-media-cache levels=1:2 keys_zone=pleroma_media_cache:10m max_size=10g
inactive=720m use_temp_path=off;this is explicitly IPv4 since Pleroma.Web.Endpoint binds on IPv4 only
and
localhost.resolves to [::0] on some systems: see issue #930upstream phoenix {
server 127.0.0.1:4000 max_fails=5 fail_timeout=60s;
}server {
server_name example.tld;listen 80; listen [::]:80; # Uncomment this if you need to use the 'webroot' method with certbot. Make sure # that the directory exists and that it is accessible by the webserver. If you followed # the guide, you already ran 'mkdir -p /var/lib/letsencrypt' to create the folder. # You may need to load this file with the ssl server block commented out, run certbot # to get the certificate, and then uncomment it. # # location ~ /\.well-known/acme-challenge { # root /var/lib/letsencrypt/; # } location / { return 301 https://$server_name$request_uri; }}
Enable SSL session caching for improved performance
ssl_session_cache shared:ssl_session_cache:10m;
server {
server_name example.tld;listen 443 ssl http2; listen [::]:443 ssl http2; ssl_session_timeout 1d; ssl_session_cache shared:MozSSL:10m; # about 40000 sessions ssl_session_tickets off; ssl_trusted_certificate /etc/letsencrypt/live/example.tld/chain.pem; ssl_certificate /etc/letsencrypt/live/example.tld/fullchain.pem; ssl_certificate_key /etc/letsencrypt/live/example.tld/privkey.pem; ssl_protocols TLSv1.2 TLSv1.3; ssl_ciphers "ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:!aNULL:!eNULL:!EXPORT:!DES:!MD5:!PSK:!RC4"; ssl_prefer_server_ciphers off; # In case of an old server with an OpenSSL version of 1.0.2 or below, # leave only prime256v1 or comment out the following line. ssl_ecdh_curve X25519:prime256v1:secp384r1:secp521r1; ssl_stapling on; ssl_stapling_verify on; gzip_vary on; gzip_proxied any; gzip_comp_level 6; gzip_buffers 16 8k; gzip_http_version 1.1; gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript application/activity+json application/atom+xml; # the nginx default is 1m, not enough for large media uploads client_max_body_size 16m; ignore_invalid_headers off; proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection "upgrade"; proxy_set_header Host $http_host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; location / { proxy_pass http://phoenix; } location ~ ^/(media|proxy) { proxy_cache pleroma_media_cache; slice 1m; proxy_cache_key $host$uri$is_args$args$slice_range; proxy_set_header Range $slice_range; proxy_cache_valid 200 206 301 304 1h; proxy_cache_lock on; proxy_ignore_client_abort on; proxy_buffering on; chunked_transfer_encoding on; proxy_pass http://phoenix; }}
