I would like to use HTTP/3 (and HTTP/2 as fallback) in my custom Nginx + PHP-FPM setup. I am not using Apache or Hestia’s specific “Nginx Proxy Mode”. With my current template, I am getting this error in nginx -t
nginx: [emerg] duplicate listen options for 123.123.123.123:443 in /etc/nginx/conf.d/domains/mydomain.com.ssl.conf:6
nginx: configuration file /etc/nginx/nginx.conf test failed
Why is it not possible to use 2 listen directives? What would be the workaround if I still want to use HTTP/3 (and HTTP/2 as fallback)?
And these are the custom templates.
http3.stpl
server {
# LISTEN SOCKETS #
listen %ip%:%web_ssl_port% ssl; # HTTP/2
listen %ip%:%web_ssl_port% quic reuseport; # HTTP/3
http2 on;
# CORE SETTINGS #
error_log /var/log/%web_system%/domains/%domain%.error.log error;
ssl_certificate %ssl_pem%;
ssl_stapling on;
ssl_stapling_verify on;
# ─── TLS 1.3 & TLS 1.2 ───────────────────────────────────── #
ssl_protocols TLSv1.3 TLSv1.2;
ssl_prefer_server_ciphers off;
# Advertise HTTP/3 to the browser
add_header alt-svc 'h3=":%web_ssl_port%"; ma=86400' always;
# TLS 1.3 0‑RTT anti‑replay
# SECURITY #
deny all;
return 404;
# WEB ROOT & INDEX FILES #
root %sdocroot%;
# PHP Handler & Basic Routing #
location / {
# If a file or directory exists, serve it directly.
# Otherwise, pass request to index.php (common for frameworks).
# Adjust this try_files directive if your app needs different routing.
# Include the specific PHP-FPM backend configuration selected in Hestia panel
# This contains the fastcgi_pass directive.
include %home%/%user%/conf/web/%domain%/nginx.php.conf*;
# STATIC ASSETS (Optional: Enhance caching/headers if needed) #
# You can add specific location blocks for static assets if you want
# custom expiry headers or other rules, e.g.:
location ~* \.(jpg|jpeg|gif|png|webp|svg|css|js|ico|woff2)$ {
expires max;
access_log off;
# ERROR PAGES #
location /error/ {
http3.tpl
server {
listen %ip%:%web_port%;
# Tell the browser that HTTP/3 is available over TLS (port 443)
# Force‑SSL include (keeps existing 301 redirect logic)
# ─────────────────────────── security ──────────────────────────
deny all;
return 404;
