Running a new hestiacp installation with sudo bash hst-install.sh --apache yes --phpfpm yes --multiphp no --vsftpd no --proftpd no --named no --mysql yes --postgresql no --exim no --dovecot no --sieve no --clamav no --spamassassin no --quota yes --api no --interactive yes --with-debs no --port 8443 --hostname {hestiacp.domain.com} --email {email-address} --password {passphrase} --lang en --force, the custom port does not take effect. There are firewall rules for port 8443.
The /usr/local/hestia/nginx/conf/nginx.conf still has displays:
server {
listen 8083 ssl;
server_name _;
root /usr/local/hestia/web;
Changing listen 8083 ssl; to listen 8443 ssl; and restarting hestiacp makes no difference. Similarly running v-change-sys-port 8443 returns:
/usr/local/hestia/func/main.sh: line 1378: /usr/local/hestia/conf/hestia.conf: Permission denied
grep: /usr/local/hestia/conf/hestia.conf: Permission denied
/usr/local/hestia/func/main.sh: line 1408: /usr/local/hestia/conf/hestia.conf: Permission denied
sort: cannot read: /usr/local/hestia/conf/hestia.conf: Permission denied
mv: failed to access '/usr/local/hestia/conf/hestia.conf.bak': Permission denied
mv: failed to access '/usr/local/hestia/conf/hestia.conf': Permission denied
rm: cannot remove '/usr/local/hestia/conf/hestia.conf.bak': Permission denied
touch: cannot touch '/usr/local/hestia/data/users/admin/system.log': Permission denied
grep: /usr/local/hestia/data/users/admin/system.log: Permission denied
/usr/local/hestia/func/main.sh: line 142: /usr/local/hestia/data/users/admin/system.log: Permission denied
/usr/local/hestia/func/main.sh: line 97: /usr/local/hestia/log/system.log: Permission denied
sed: couldn't open temporary file /usr/local/hestia/nginx/conf/sedLPVAXU: Permission denied
sed: couldn't open temporary file /usr/local/hestia/data/firewall/sedu6Yct2: Permission denied
sed: can't read /usr/local/hestia/data/firewall/chains.conf: Permission denied
When the command is run as root, it returns v-change-sys-port: command not found
The control panel is accessible when using port 8083.
