I’m intrigued about the custom.sh that was mentioned for adding in custom rules to the firewall after a reboot. I created custom.sh:
[email protected]:/usr/local/hestia/data/firewall# ls -lh
total 16K
-rw-rw---- 1 root root 0 Dec 16 15:45 banlist.conf
-rw-rw---- 1 root root 228 Dec 16 15:44 chains.conf
-rwxr-xr-x 1 root root 1.6K Dec 16 15:40 custom.sh
drwxr-xr-x 2 root root 4.0K Dec 16 14:57 ipset
-rw-r--r-- 1 root root 0 Dec 16 15:14 ipset.conf
-rw-r--r-- 1 root root 2.7K Dec 16 15:25 rules.conf
With the contents:
ipt4="$(command -v iptables)"
ipt6="$(command -v ip6tables)"
# add maltrail rules
/usr/sbin/ipset -q create maltrail hash:net
$ipt4 -I INPUT -m set --match-set maltrail src -j DROP
# Flush all rules and delete all chains
# for a clean startup
$ipt6 -F
$ipt6 -X
# Zero out all counters
$ipt6 -Z
# Default policies: deny all incoming
# Unrestricted outgoing
$ipt6 -P INPUT DROP
$ipt6 -P FORWARD DROP
$ipt6 -P OUTPUT ACCEPT
# Must allow loopback interface
$ipt6 -A INPUT -i lo -j ACCEPT
# Reject connection attempts not initiated from the host
# $ipt6 -A INPUT -p tcp --syn -j DROP
# Allow return connections initiated from the host
$ipt6 -A INPUT -m conntrack --ctstate ESTABLISHED,RELATED -j ACCEPT
# Accept all ICMP v6 packets
$ipt6 -A INPUT -p icmpv6 -j ACCEPT
# Optional rules to allow other LAN hosts access to services. Delete $ipt6 -A INPUT -p tcp --syn -j DROP
# Allow DHCPv6 from LAN only
$ipt6 -A INPUT -m state --state NEW -m udp -p udp -s fe80::/10 --dport 546 -j ACCEPT
# Allow connections from SSH clients
$ipt6 -A INPUT -m state --state NEW -m tcp -p tcp --dport 22 -j ACCEPT
# Allow HTTP and HTTPS traffic
$ipt6 -A INPUT -m state --state NEW -m tcp -p tcp --dport 80 -j ACCEPT
$ipt6 -A INPUT -m state --state NEW -m tcp -p tcp --dport 443 -j ACCEPT
# Allow access to SMTP, POP3, and IMAP
$ipt6 -A INPUT -m state --state NEW -p tcp -m multiport --dport 25,110,143 -j ACCEPT
The ipv6 rules are created - but for some reason not:
And its also missing some custom rules I have in the firewall (for example, por 8983 for solr)
Am I missing a step?
