I am using it post install, can this project integrate with hestiacp installer? It uses iptables too.
Just did some google research and havent found any “active” project site that also have a good documentation. Also I think ddos protection needs to be a layer higher than on application level.
Yes, been long not active.
Anyway, do you think in the future of hcp, it can include an “advanced” iptables editing form (just like apache/nginx/mysql advanced edit form)?
I am using a custom iptables config in .sh format (works on vestacp, it is ran every boot and complement existing vesta iptables) , i tried to put in hestia but it overwrites the hestia iptables setting and subsequently being removed on boot.
