I am trying to install on a server with Debian 10 and I am getting this error
the same error occurs, it must be a script problem please check it
It’s no script error. Most likely apt is not able to access one of the repositories, like described in the thread tjat @eris linked above.
Please read the part about changing the apt get command in the install script to ne more verbose.
Maybe the problem is even the same with sury…
Please check your error log first
Those can be found in your /root directory
A week ago I installed a Debian 10 and had no problems, now I try to install it and that error occurs. I don’t think it’s a system problem, I found another thread in another user’s forum with the same error and they don’t give a solution.
Did you noticed the post of @falzo? It isnt a script issue, there has been no change within the week you mention…
then there must be some Debian error, I will install it on a ubuntu
Please check first your log files to see what the cause of the error is. Also for further cases…
