Some debian 10 installs, after reboot loses the additional ips added in hestiacp
the network not up
I need remove all IPs in hestiacp and re-add and so works again.
the network/interfaces file seems ok … the same
are there another tip for fix it without do this process ?
So… I used hestiacp and vestacp in a lot of servers … more than 3000 …
some servers somentimes, after a reboot… dont UP the extra (additional) IPs
Normally, I add by panel
IP
MASK
select the network interface
save
so the network works … fine …
but, after reboot … stop works with message “cant bind() addressX”
So … I go to panel, remove IPs and re-add … and back to works
Please add ip addresses and then copy paste the network / net plan config maybe we can see any issues feel free to send a pm if you don’t want to paste it in Public
netplan is not installed …
I checked that hestiacp is writing directly on interfaces
After reboot, if I run command ip add xxx xxx etc
the ip works
---- test 2
So, I installed netplan.io … I tested again, and now after reboot the ip was not lost
but
Now, I am receiving this error message
/usr/local/hestia/bin/v-update-firewall: line 180: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 181: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 182: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 183: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 184: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 185: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 186: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 187: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 188: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
chmod: cannot access ‘/usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks’: No such file or directory
