Hello good morning.
Is it safe to use Debian 12 to install the Hestia server?
Or is it still on trial?
Hello good morning.
supported and stable.
Yes, I update to 12
BUT, debian 11 to 12 differences in performance
debian 11 used 650 ~700mb
debian 12 used 1000gb
debian 11 used 70% cpu
debian 12 go to 100% cpu in performance peaks
with that increase, there seems to be another issue with your server.
@Raphael thank for alert
do you have any tips to check what might be going on?
the server has the highest access numbers between 6:00 pm and 10:00 pm.
Nothing has been changed except an update to debian 12…
no, not really. can basicly be a lot, needs some debug.
Thank you very much already decided to install it
