Even if i haven’t added the subdomain to hestiacp, it still shows the default page because i added it on my dns, pointing to the server. how do i fix this? i don’t want to add a subdomain for any unhandled open dns routes
- new hestia user
That’s the default page the web server serves when it doesn’t find a matching virtual host. The content of that page is located in /var/www/html/.
What would you like to happen instead of showing that page?
probably a default thing to block any traffic?
Then edit /etc/nginx/conf.d/a.b.c.d.conf where a.b.c.d is your server’s ip and add return 444; after error_log directive in both server blocks
Something like this:
server {
listen a.b.c.d:80 default_server;
server_name _;
access_log off;
error_log /dev/null;
return 444;
location / {
proxy_pass http://a.b.c.d:8080;
server {
listen a.b.c.d:443 default_server ssl;
server_name _;
access_log off;
return 444;
ssl_certificate /usr/local/hestia/ssl/certificate.crt;
ssl_certificate_key /usr/local/hestia/ssl/certificate.key;
return 301 http://$host$request_uri;
location / {
root /var/www/document_errors/;
location /error/ {
alias /var/www/document_errors/;
Save the file and reload nginx:
systemctl reload nginx
