how to recover a deleted folder on the panel
Restore from backup
I’ve checked the backup and the folder isn’t there.
what procedure should i follow
What was the folder path?
/home/blogs/web/folder
I guess folder is a web domain and if you backed up your Hestia user, that folder should be in the backup. How did you check that the folder doesn’t exist in your backup?
The folder could be in the backup only if the hestia user name was “blog”. If it was, then it cannot be there if it was created after the backup began.
If the username was not “blog”, then it will remain outside of the hestia system.
