Deleting a user does not remove their backups
I deleted a user but their backups still exist!
We currently don’t delete them. Don’t know if we should consider this to be a bug. I personally like the idea that at least the backups are saved.
I think a check box in a pop up confirmation user delete modal to remove Backups should solve both situations. That way you know it keeps them unless you check the box
Personaly, i think the current behaviour is correct. If you remove a user, even by mistake, a checkbox would force you to remove the backup aswell. Its better to delete the backup manualy afterwards.
That would be a really easy thing to make a mistake on. I agree with the others that deleting backups should be a completely separate process so no accidental mistakes can happen.
Totally agree with you
