Hello!
Could you help to understand where find solution for following issue:
- I tested email by https://www.mail-tester.com and on this server there is issue with:
|-1.274|RDNS_NONE|Delivered to internal network by a host with no rDNS
This may indicate you do not have a rDNS configured for your hostname or the rDNS does not match your sending IP|
You’re not fully authenticated
We check if the server you are sending from is authenticated
Your message is not signed with DKIM
DomainKeys Identified Mail (DKIM) is a method for associating a domain name to an email message, thereby allowing a person, role, or organization to claim some responsibility for the message.
But i added DKIM via records
On others servers everything is ok, 10 from 10 points
Can’t understand where need to find and fix
Your IP address 5.******* is associated with the domain 3(NXDOMAIN).
Nevertheless your message appears to be sent from ******ask.com.
You may want to change your pointer (PTR type) DNS record and the host name of your server to the same value.
Here are the tested values for this check:
- IP: 5.2********
- HELO: *******ask.com
- rDNS: 3(NXDOMAIN)
