I am about to migrate 100 WordPress Domains to a Hestia Machine and I have been doing some testing.
For now, I have a script that:
creates user
assigns domain
creates database
uses wp-cli to install wordpress
retrieves wp-content.zip via SCP
unzips
changes permissions
retrieves database.zip via SCP
uses wp-cli to import database
I do not have a valid SSL yet since it is a test and I have not published the website yet.
Problem: I can correctly see the homepage but I can’t see any other page or even /wp-admin
I cannot reflush permalinks and when I did via wp-cli it had no effect.
It is because your SITEURL is setup for httpS but as you don’t have SSL installed on your HestiaCP, it creates a forced loop. You have 2 options:
Get and Change your SITEURL using WP-CLI to http (non-ssl)
or
Issue an SSL, Lets Encrypt or Self-assigned so that your https URL loads
To test without publishing DNS, you can use hosts file entry in your computer.
Once you feel satisfied, change A records, go live with your site from Hestia Server and then issue fresh LE SSL certificate.
Might be unrelated, but I recently had a string of problems migrating sites between servers with the “Too many redirects” error. Turns out it was a plugin called SimpleSSL. I had to disable it using wp-cli before I could access anything. Maybe something similar is happening with you? Perhaps try disabling plugins before you migrate?
Okay I am redefining now. What has been happening.
If I uncheck the SSL option, then I can’t see the website. If I check it, I can’t unless I publish the website.
I did this to fix the issue:
cat ssl-fix.sh
#!/bin/bash #Define custom functions to use across scripts
source ./functions.sh
get_user_domain $1 $2 #Create Self-Signed certificates
path=“/home/$username/web/$domain/ssl-cert”
mkdir $path
crt=“$domain.crt”
key=“$domain.key”
arg=“/countryName=ES/localityName=Madrid/organizationalUnitName=$domain/commonName=$username/emailAddress=spam@$domain”
msg “Creo los certificados”
openssl req -newkey rsa:2048 -x509 -sha256 -days 3650 -nodes -out $path/$crt -keyout $path/$key -subj $arg
ls $path #Create Self Signed Certificates
msg “Aplico los certificados AUTOFIRMADOS a $domain”
$HESTIA/bin/v-add-web-domain-ssl $username $domain $path #Force SSL
msg “Fuerzo redirección a https://$domain”
$HESTIA/bin/v-add-web-domain-ssl-force $username $domain #Try to install Let’s Encrypt as a bonus.
msg “Intento instalar Let’s Encrypt (fallará si el dominio no está publicado)”
$HESTIA/bin/v-add-letsencrypt-domain $username $domain www.$domain
Now I have everything in SSL with a 10-year self signed certificate so I can check if it works and the system tries to install a Let’s Encrypt certificate. If it suceeds, everything is normal if it doesn’t it will be likely because the website is not published yet and I will have to repeat this later.
SSL plugins can cause force redirect loops, so yes, you have to disable them if testing.
Your ‘terminology’ is still not understandable, what do you mean by ‘publish’ the website, you mean publishing the DNS A records to go live ?
Issuing a selfe signed SSL has nothing to do with DNS at all. And then you can test the site with hosts file entry. The only thing is it will nag you to load site from unknown certificate… but Firefox would let you go in. Safari / Chrome may need additional clicking of a few things and configuring their settings to allow self signed certs… But thats a browser problem and not server side thing.
I use hosts file but hestia doesn’t work out of the box unlike Plesk.
With Plesk I could provision a server and then connect to it just pointing my hosts file to the server.
With Hestia I have to create my self-signed certificate, and then I can point my hosts or propagate DNS A record and use let’s encrypt.
I thought that I could just install wordpress and point the hosts file and it should be fine.
That is not accurate I use hosts file (and fiddler) all the time with domains in Hestia and I don’t have issues. If a domain (that I want to test/move to Hestia) already has a certificate, I copy the certificate keys (private, public, chain) from the original hosting server into the 3 boxes in Hestia web domain. That way I don’t get any certificate errors while doing my tests on Hestia. After checking that everything is all right, I update the NS records to point to the Hestia server. After about 48h, I use LE on the Hestia server to get a new certificate (so that it will auto-renew).
