Disable and stop ClamAV without uninstalling
How can I disable and stop clamav correctly on the system without uninstalling it?
Following these steps:
Clamav and spamassassin - #4 by eris
Remove clamav-daemon and spamd - #6 by sahsanu
  1. I ran:
systemctl disable clamav-daemon
systemctl stop clamav-daemon
  1. In /etc/exim4/exim4.conf.template I uncommented # CLAMD = yes
But in the exim4 mainlog i get:
2025-12-10 12:26:14 1vTIKk-XXX-1QwI malware acl condition: clamd /run/clamav/clamd.ctl : unable to connect to UNIX socket (/run/clamav/clamd.ctl): No such file or directory
2025-12-10 12:27:09 1vTILc-XXX-3ZIP malware acl condition: clamd /run/clamav/clamd.ctl : unable to connect to UNIX socket (/run/clamav/clamd.ctl): No such file or directory
2025-12-10 12:27:59 1vTIMR-XXX-0TCf malware acl condition: clamd /run/clamav/clamd.ctl : unable to connect to UNIX socket (/run/clamav/clamd.ctl): No such file or directory
Than i ran:
sudo systemctl stop clamav-daemon.socket
sudo systemctl disable clamav-daemon.socket
But no luck. Did i miss something?
Do i need to also uncomment in exim4 config?:
.ifdef CLAMD
av_scanner = clamd: /run/clamav/clamd.ctl
.endif
So ideally i would end up:
UNIT FILE                                    STATE           PRESET
clamav-clamonacc.service                     disabled        enabled
clamav-daemon.service                        disabled        enabled
clamav-freshclam-once.service                disabled        enabled
clamav-freshclam.service                     enabled         enabled
Did you restart exim to apply the changes?
systemctl restart exim4
Also, don’t forget:
v-change-sys-config-value ANTIVIRUS_SYSTEM ''
Awesome! It’s working now, recap:
# CLAMD = yes
Note: CLAMD = no did not work for me.
And also in /etc/exim4/exim4.conf.template I uncommented:
#.ifdef CLAMD
#av_scanner = clamd: /run/clamav/clamd.ctl
#.endif
Than i checked services with:
systemctl list-unit-files --type=service
for desired outcome:
And did some testing sending emails. No more exim mainlog errors like these: malware acl condition: clamd /run/clamav/clamd.ctl : unable to connect to UNIX socket (/run/clamav/clamd.ctl): No such file or directory Thanks!
Follow-up:
It doesn’t matter what text you assign to the CLAMD variable in Exim, it only checks whether the variable is defined or not. So the only way is to comment out that line… or remove it :wink:
You don’t need to comment out those lines but it won’t hurt :wink:
I would disable freshclam too, if clamav is disabled, you shouldn’t have the freshclam service enabled.
Thanks for sharing the recap :slight_smile:
Thanks for following up @sahsanu!
  • The CLAMD = no suggestion i got here in another post.
  • Good to know, i read it in the same post but at least now it’s very clear that ifdef CLAMD is not active :stuck_out_tongue:
  • Thanks that you mention that clamav-freshclam.service shouldn’t be enabled. I thought i leave it for now just in case i want to reenable ClamAV in a short time. I’ll disable it too.
sudo systemctl disable clamav-freshclam.service
sudo systemctl disable clamav-freshclam-once.service
sudo systemctl stop clamav-freshclam.service
sudo systemctl stop clamav-freshclam-once.service
