Hi -
It seems like Multi-PHP is causing a crash in our system. So, is it possible to disable the function for a domain or user?. If not, how do you disable/enable it for the whole system?
Thanks for your help and regards,
Hi -
For php-fpm
v-delete-web-php x.x
Where the x.x is the versions you want to remove
