Disable pop3 and change IMAP port
hi, i want to disable pop3 email feature in dovecot and i tried by removing dovecot-pop3d but that is breaking hestiacp’s settings and giving error (sometimes service get stopped). So, is there any way to disable it from configuration file ? However, i have already deny port at firewall but if it stop completely than that would be good.
and how can i change port number of IMAP ?
Hi @chetanp,
Edit /etc/dovecot/dovecot.conf file and remove pop3 from protocols directive:
Before:
protocols = imap pop3
After:
protocols = imap
Save the file and restart dovecot:
systemctl restart dovecot
Edit file /etc/dovecot/conf.d/10-master.conf and add port directive to imap and imaps.
Example changing imap from default port 143 to 144 and imaps from default port 993 to 994:
Before:
service imap-login {
  inet_listener imap {
  inet_listener imaps {
After:
    port = 144
    port = 994
Save the file and restart dovecot.
