Disabling static asset cache nightmare
I’m confused that something as simple as disabling cache headers on static assets appears to not be possible without editing some funky config file whose path eludes me. I’m using what equates to a default Hestia install.
Since nginx handles static assets like CSS and JS, using mod_headers in my .htaccess doesn’t work for disabling cache on these files. So I created an nginx.conf_custom file and put it in /home/foobar/conf/web/portal.foobar.com/nginx.conf_custom. It contains:
location ~* .(jpg|jpeg|png|gif|ico|css|js|woff|woff2|ttf|svg|otf|eot)$ {
add_header Cache-Control “no-cache, no-store, must-revalidate” always;
add_header Pragma “no-cache” always;
add_header Expires 0 always;
I ran v-rebuild-web-domain foobar portal.foobar.com and sudo systemctl restart nginx and nothing has changed. The default template contains the expires max header that for some reason I can’t override.
server {
        listen      %ip%:%proxy_ssl_port% ssl;
        error_log   /var/log/%web_system%/domains/%domain%.error.log error;
        ssl_stapling        on;
        ssl_stapling_verify on;
        # TLS 1.3 0-RTT anti-replay
                deny all;
                return 404;
        location / {
                proxy_ssl_server_name on;
                proxy_ssl_name $host;
                location ~* ^.+\.(%proxy_extensions%)$ {
                        try_files  $uri @fallback;
                        root       %sdocroot%;
                        expires    max;
        location @fallback {
        location /error/ {
        proxy_hide_header Upgrade;
What do I do here?
