Hello everyone.
Since the last update I am noticing that when creating a new user, entering that user, then creating a site/domain and activating the “dns support” and “mail support” options, after the last update (at least since I noticed) it is not auto-generating the DKIM in the DNS Records.
Even after activating the “DKIM Support” option in the email section of that domain.
Does it happen to anyone else? I have a production server and a small test server, the same thing happens on both.
Thanks and regards!
PS: after several “uncheck->save/check->save/uncheck->save/check->save” in the “Support DKIM” in the mail option, it’s generated and added to DNS Records. (in both servers)
No. I just checked last update and new install and the DKIM generation is in there. You might want to peruse your templates.
What’s template are you referring? Tell me to check it please. Thanks
HestiaCP uses DNS templates to standardize zone configurations, stored in /usr/local/hestia/data/templates/dns/. These templates contain placeholders (like %ip% or %domain_idn%) that are replaced with user-specific variables when a domain is added or rebuilt.
Available Built-in Templates:
default: Standard configuration for most use cases.
default-nomail: Standard configuration excluding mail records.
gmail: Configures records for Google Workspace.
office365: Configures records for Microsoft 365 (Exchange).
zoho: Configures records for Zoho mail.
child-ns: Used when the domain acts as a name server.
Management and Customization: Administrators can update templates using the command v-update-dns-templates. Custom templates can be created in the active templates directory and applied by rebuilding domains with v-rebuild-dns-domains user. When editing a DNS zone in the UI, users can select the appropriate template from the dropdown, though granular permission controls to restrict this selection are currently a feature request.
well.. I recheck my local templates with github version and no differences.. also the script v-add-dns-record so maybe was a temp error, in both servers.
Thanks for your time @durglewankelshteim
You can test it by adding a domain with the DNS option checked like test1.mydomain and see what it creates. All the best!
Yes, I have tried several ways.
- Creating domain without DNS and without email (Then creating both)
- Creating domain with DNS and then email
- Creating domain without DNS but with email.
But don’t worry, in the latest hestia update 1.9.8 I found that it was resolved (at least it didn’t happen again). I was looking at the changelog and maybe it is due to a fix in v-list-mail-domain-ssl
Thanks again for the follow-up.
Glad it is now resolved for you. All the best!
