You need to make some changes in bind configuration:
Yes, bind and sync is working without dnssec. and thats the problem with this FAQ.
on Master i dont have changed hestia.conf setting DNS_CLUSTER_SYSTEM
on slave i have changed ist to hestia-zone
so the sync is working.
BUT:
i can not activate DNSSEC on master only on slave. so should i change this setting on both? Master ans Slave?
and if i do so, i can not sync to salve anymore.
You should activate it on the master.
How ever you need to make the changes:
Mainly:
- In
/usr/local/hestia/conf/hestia.conf, changeDNS_CLUSTER_SYSTEM='hestia'toDNS_CLUSTER_SYSTEM='hestia-zone'. - On the master server, open
/etc/bind/named.conf.options, do the following changes, then restart bind9 withsystemctl restart bind9.
bash
# Change this line
allow-transfer { "none"; };
# To this
allow-transfer { your.slave.ip.address; };
# Or this, if adding multiple slaves
allow-transfer { first.slave.ip.address; second.slave.ip.address; };
# Add this line, if adding multiple slaves
also-notify { second.slave.ip.address; };
- On the slave server, open
/etc/bind/named.conf.options, do the following changes, then restart bind9 withsystemctl restart bind9:
bash
# Change this line
allow-recursion { 127.0.0.1; ::1; };
# To this
allow-recursion { 127.0.0.1; ::1; your.master.ip.address; };
# Add this line
allow-notify{ your.master.ip.address; };
Also make sure you OS is Ubuntu 22.04 or Debian 11 or higher
Yes,
should i do this on master, slave or both?
- In
Only master is enough
okay, so on master i change it to hestia-zone and on slave it is hestia.
if i change it all zones on slave are empty. i have removed cluster and reenabled it and it ist also empty on slave
That is correct
If you run:
rndc notify domain.com on the master
It will sync up with the slave
Just create a new DNS record and verify if it is working via
nslookup domain.com ns2.server.com
okay. ist seems to work, but in webinterface i see no records on slave. is this correct?
on master i have 34 Records
That is correct we don’t store the records in hestia config any more
oh. than it is all fine
Should the response indicate “Non-authoritative answer” for that record?
and
Does this mean that when executing v-list-dns-domains command on slave server that there will be nothing shown as well?
No I get:
Server: ns2.vxx.domain
Address: ip::1#53
Address: ip
Voor both name servers…
And DNS only lists the zones and not the record
