DNS Cluster not working
I followed the instructions on the website verbatim.
I changed the setting from hestia to hestia-zone on both the master and slave.
I made the applicable changes to named.conf.option, reflecting back to its counterparts. IE master/slave external IPs.
Ran v-add-remote-dns-host with the api key pair. No errors were thrown.
Verified that the cluster conf file was created on the master.
I have created new test domains in the web page, by cli, no transfers are initiated.
I am using NAT on my pfsense firewall. Even tried 1:1, same result.
When I run the command -
root@hosting2:/home/happydns# v-list-dns-domains happydns
DOMAIN IP TPL TTL DNSSEC REC SPND DATE
Nothing shows up. At this point I am perplexed. guidance?
v-sync-dns-cluster works properly?
