I’ve got a question about DNS configuration. I’m using DigitalOcean and have installed Hestia. I would normally set up the DNS records for domain.com in DigitalOcean, but as my knowledge grow I think I should configure them in the Hestia panel.
Once I ask about LE certificate with wildcard which could not be validated because I was using external DNS. If I setup the DNS in the Hestia panel…
1- Will wildcard certificate validation succeed?
2- The Use Lets Encrypt to obtain SSL certificate option will request a Wildcard Certificate?
And finally if I use the DNS configuration in Hestia, could I leave the ns1.digitailocean.com on my domain delegation or should I change it to something like ns1.domain.com (the ones configured in the Hestia panel)
