DNS sync with cloudflare
How can i sync DNS records with Cloudflare using API
You can’t
Yes you can. Someone needs to code it though.
There are many who’ve succeeded in doing this using their api. You just need to cronjob updates using a token with the right credentials for each domain for which you use cloudflare dns.
Here’s an example use-case; GitHub - fire1ce/DDNS-Cloudflare-Bash: Cloudflare DDNS bash Script for most Linux distributions and MacOS. Choose any source IP address to update external or internal (WAN/LAN). Cloudflare's options proxy and TTL configurable via the parameters.
And for now, the main question I have is:
  • What do you do if you use cloudflare for hosting your DNS records?
    Do you Enable or Disable DNS system in hestia? I seem to have disabled it long ago, but now after every hestia update I get:
Error: DNS_SYSTEM is not enabled
whenever I add new alias domains etc.
We are open source feel fee to commit an PR or fund the development for it…
