Although DNSSEC is present, “View Public DNSSEC Key” is missing.
HestiaCp v1.7.1, Debian 11.6. I have no idea where to look and what to check! Can you guide me, help me with this?
Thanks to the Hestia team, you are doing a great job.
Solved. DNS clusters and DNSSEC | Hestia Control Panel
DNSSEC can’t be used when Hestia Cluster is active as Master ↔ Master
Converting an existing DNS cluster to Master → Slave
- In
/usr/local/hestia/conf/hestia.conf, changeDNS_CLUSTER_SYSTEM='hestia'toDNS_CLUSTER_SYSTEM='hestia-zone'.
Version is 9.16 and it in smaller then 9.18 …
So it isn’t supported…
Only 9.18 (Debian 11 or Ubuntu 22.04) are working fine…
Hestia runs in vm, proxmox, Debian 11.6 bullseye. Could I solve it somehow?
Please update following files
It works fine in Ubuntu, not in Debian. Regardless of which version of Debian I install, 11.1, 11.6, bind 1.16 comes installed by default.
I know version check is wrong see the changes in the PR I have made
You can install BIND 9.18 from backports.
version=$(named -v | awk ‘NR==1{print $2}’)
if version_ge ‘9.18’ $version; then
check_result “$E_DISABLED” “DNSSEC is not supported when bind / named < 9.18”
check_result “$E_DISABLED” “DNSSEC is not supported when bind / named version <= 9.16.18”
fi
It worked with a little modification. I also changed this if version_ge ‘9.16’ $version; then.
Thank you @eris . Today I learned something else. I appreciate your patience.
